Fuel pump leak
Phil
04-17-2001 11:02:11
I just thought of another small problem on the JD 450.
I have a small leak at the output line of the fuel pump. It is tight. If I remove the fuel line to replace, will I have to worry about air locks in the system?
My fuel pump does not have the manual prime lever that is shown in the operating manual.
I guess I could loosen the line at the filter and turn engine over to pump out air and then tighten if I replace the fuel line?
I know these questions are basic, but I've never done much work on diesels before. Just lots of old gas farm tractors.
Phil
jerry Gerthofer
04-17-2001 13:30:10
 Re: fuel pump leak in reply to Phil, 04-17-2001 11:02:11
you should be o.k. replace the line see what happens
