D4 cat # 6u2547
hobby farmer
06-29-2003 14:51:43
Fuel injection ? Fuel to top of injectors. nothing but white smoke. will run on gas fumes.
Bob/Ont
06-29-2003 19:17:15
 Re: D4 cat # 6u2547 in reply to hobby farmer, 06-29-2003 14:51:43
Just what are you doing there? I take it you have blead the injectors and it will not start, just white exh smoke. Is that correct?
Come on Back Bob
hobby farmer
07-14-2003 10:02:13
 Re: Re: D4 cat # 6u2547 in reply to Bob/Ont, 06-29-2003 19:17:15
Yes , but it will run on gas fumes.
Deas Plant.
06-30-2003 02:28:22
Hi, Hobby Farmer. I suppose this might sound like a stupid question but, are you releasing the decompressor -- or is it releasing when you move the lever.
White smoke, as I understand it, is diesel fuel that has not been burnt at all. This could be because of lack of compression or because the timing is off.
Hope this helps.
You have a wonderful day. Best wishes. Deas Plant.
hobby farmer
07-14-2003 10:05:46
 Re: Re: Re: D4 cat # 6u2547 in reply to Deas Plant., 06-30-2003 02:28:22
Yes I am releasing the decompressor. Not a bad question i did forget at first. the white smoke is so very little and it does run on gas fumes through the intake.
hobby farmer
08-24-2003 08:00:12
 Re: Re: Re: Re: D4 cat # 6u2547 in reply to hobby farmer, 07-14-2003 10:05:46
Hey i did get the cat running it turned out to be valves not closing completly. a little tap with a rubber hammer and away we go. steering clutchs stuck of course. but a little brake cleaner and a trip around the field broke them loose. Looks like now i need to replace the clutch,etc. any suggestions would be nice. Thanks again hobby farmer
hobby farmer
08-24-2003 08:02:49
 Re: Re: Re: Re: Re: D4 cat # 6u2547 in reply to hobby farmer, 08-24-2003 08:00:12
Does anyone know what year this cat is 6u2547 is the serial # Thanks
