655 idlers
Pete Burghart
07-02-2003 14:02:29
Does anyone know where i can locate idlers for a 655 allis chalmers track loader or info on possible retrofit or repair.
Ray
07-02-2003 15:03:00
 Re: 655 idlers in reply to Pete Burghart, 07-02-2003 14:02:29
Pete, I think I talked to you some time ago about this machine and was not able to help you at the time. were are you located, Maybe I can rebuild the ones you have. What is wrong with the idlers, Are the bearing out of them or are the flanges wore off or broken. Let me know maybe I can fix something up for you. Thanks, Ray
Brokenwrench
07-02-2003 15:02:56
If they are not cracked,and the bosses where the bearings run are still good, a reputable undercarriage shop should be able to weld them up to original specs.and reseal the bearings.
