Gehl CTL60 Rubber Track Loader??? Help!!!
Jeff
07-04-2003 21:29:32
Hi, I Have a Gehl CTL60 rubber track loader. tonight while working with it I thru a track, does anyone know how to put the track back on??? I have her on the level now and the left side jacked up ready to try and start to put her back on. i'm thinking to release the grease pressure screw and hopefully that will give me enough slack to put the track back in place????? am I thinking right??? please help if you can Jeff.
AJ
07-05-2003 02:20:40
 Re: Gehl CTL60 Rubber Track Loader??? Help!!! in reply to Jeff , 07-04-2003 21:29:32
That's what you have to do,remove the grease valve,push the idler back,put the track along side the frame,lift it on to the idler,put a bar through the loop at the back and engage it in the sprocket,hold it up at an angle and get a second person to reverse the sprocket and it will go back on,pump it up.
AJ
Jeff
07-05-2003 18:22:36
 Re: Re: Gehl CTL60 Rubber Track Loader??? Help!!! in reply to AJ, 07-05-2003 02:20:40
Thanks for your Help AJ!!! I got her back together with a little help from my brother. Jeff
