JD 350 Right track lacks power.
Norm Carl Jr
07-08-2003 06:33:06
I recently purchaced a JD350 crawler and the right side track seems to lack power when turning or when under stress. I understand that fluid level might be low but its always is the right track. Is there any filters or screens that might be pulged? If so where are they. Any help would be great!
Norm Carl
Lavoy
07-08-2003 08:40:33
 Re: JD 350 Right track lacks power. in reply to Norm Carl Jr, 07-08-2003 06:33:06
If the power loss is due to any low fluids, it would affect both tracks, not just one. I would guess that you have a bad steering clutch.
As far as fluids being low, the only one that would affect things is the reverser, do not run it low, it is quite a job to remove it and rebuild it.
Lavoy
Norm Carl Jr
07-09-2003 05:20:29
 Re: Re: JD 350 Right track lacks power. in reply to Lavoy, 07-08-2003 08:40:33
The guy I bought this machine from said that he relaced the clutches and brakes, but you never know. I believe its a plain JD 350 but I havent been able to get a comfirmation. I talked to the local JD dealer with the serial number but they didnt show that number. The hydro lever is on the dash and it has in line hydrolic cylinders in the steering linkage. He also said and you can see that he replaced the rails and rollers and sprockets. Any suggestions on the model/year and any adjustments that might need to be made? He told me about adjusting the brakes after about 10 hours. Thanks alot for all the info. You guys should get together and write a book or something!
Norm Carl Jr
Norm Carl Jr
07-08-2003 08:54:29
Thank you for the info. I have read about adjusting the steering clutches and am wondering if that may be the problem. I have been unable to find a manual for this machine yet (just started looking) and any info on the procedure to adjust the clutches would be great! Again thanks for the reply.
jdemaris
07-08-2003 19:30:35
 Re: Re: Re: JD 350 Right track lacks power. in reply to Norm Carl Jr, 07-08-2003 08:54:29
Assuming you have a 350 or a 350B and not a 350C or later, you have dry steering clutches. Like any spring-loaded clutch, there must be free play between the throughout bearing and the fingers of the clutch pressure-plate. Check to see if there's any play in the steering lever that goes to the right clutch. If there isn't, adjust it. If there is, you'll probably have to split the track, pull the final drive, and fix it. Under the seat there is a steel cover with four bolts on each final drive, i.e. two covers. Pull the right cover off and there is linkage inside along with an initial adjuster for the brake band. You can usually adjust free play for the clutch with the linkage. It is also possible, if necessary, to adjust the fingers on the pressure plate from the top, but it's difficult. If the clutch fibers have gotten damp and swelled up, you'll have a hard time getting free play. With the steering lever adjusted properly, there should be a small amount of free play (1/2 to 1" is okay), then contact should be made with the clutch pressure-plate, and as the lever is pulled back, the clutch should be disengaged when the brake takes hold. With the crawler adjusted properly, you can be on a hill, facing down, with the machine in reverse. Hold both levers back so the brakes hold. Then, slowly let them forward and there should be a point when the crawler starts to roll down the hill. Then as you let the levers out a little more it will start to back up.
Norm Carl Jr
07-09-2003 05:10:32
 Re: Re: Re: Re: JD 350 Right track lacks power. in reply to jdemaris, 07-08-2003 19:30:35
Thank you very much for the info I'll check those adjustments.
Norm Carl
