JD 350B steering brake
Jaj in Mich
07-15-2003 13:34:00
I have a 350B Crawler/Loader Serial #1380851 with power assist steering. Last night, with no worning the L.H. steering brake stopped working completly. The clutch still works great on that side because I can pull back on both levers at the same time and it rolls to a stop. When I let up on the L.H. lever it begins to move again as normal. The R.H hand works as normal. I looked at the owners manual and decided the first line of action would be to check the adjustment on clutch and brake linkage. I removed both of the top inspection plates and backed off adjustments as described in the manual. Here's the question: A.) The steering handle grip is to be 2" from the dash when adjusting free play>>> mine is 2 1/2" and bottoms out on the stops which are small posts mounted to the floor board. In order to attain the 2" dimension I would have to either bend the lever back or grind down the posts. Is this dimension that critical or can I just proceed with rest of the prescribed adjustment? B.) Am I wasting my time doing this adjustment thing and should I be, instead, starting to tear the thing apart and replace the brake and/or what ever could have broke in there? I'm trying the easy stuff 1st but I guess it doesn't really make any sense that something would simply get that far out of adjustment in such a short time. Or does it??
Thank you for any in put into this matter.
