671 Detroit Diesel chain driven oil pump
Justin Drenth
07-23-2003 08:01:21
I recently took the front and rear oilpans off the 671 Detroit Diesel that's in my AC HD19 for some cleaning and to check the oil intake screens. While looking around a bit I noticed that the chain that drives the oil pump from the crankshaft is quite loose. The sprockets look to be in good shape-little or no hooking. What's happened here? Has the chain stretched? Missing chain tensioner?
The service manual I have for this machine describes a gear driven oil pump so I can only assume this oil pump and/or engine has been replaced in the past. The HD19's year is 1949-ish.
Thanks for any help.
Lee Bradley
07-28-2003 12:24:14
 Re: 671 Detroit Diesel chain driven oil pump in reply to Justin Drenth, 07-23-2003 08:01:21
My manuals show chain drive oil pumps for the HD-7, 10, 14. That is 3, 4, 6-71 engines AC used from 1940 to 1950. Your 19 is a little newer but I don't know when GM changed to gear drive. The manual doesn't show a tensioner. One interesting thing; all three engines used the same pump, just a different size sprocket to drive the pump faster on the engines with more bearings to supply.
