JD350 Steering Clutches
JIm
07-23-2003 14:57:58
Looking for some info on JD350 Steering clutches.
Do you have to take the fuel tank and hydraulic tank off to change the clutches?The service manual says you have to too get the clutches out but in another part of the manual it doesn't say that to get the final drive off. I can't seem to get the same answer twice, I am ready to take the drive off and I don't want to get into a problem so does anybody have a opinion on this?
Clunkhead
08-17-2003 05:33:58
 Re: JD350 Steering Clutches in reply to JIm, 07-23-2003 14:57:58
The fuel and hyd. tanks do not need to come off. Have a service maual and beg borrow or steal a clutch hieght adjustment tool. Its very important to adjust the clutch arms hieght once you have reassembled the clutch assembly. I use long threaded rods and a floor jack to guide the final housings off the shafts without damaging things. Also it pays to have a large muscular friend to help you with the assembly once its detached from the frame. Crawlerheaven was a huge help with parts and advice to me regardless of his popularity with YT.
Steve
07-24-2003 04:37:30
third party image
If and when you need clutch discs, give us a try. Check us out on the web.
D. Andrews
07-24-2003 08:01:57
 Re: Re: JD350 Steering Clutches in reply to Steve , 07-24-2003 04:37:30
went to look at your page Link for Komatsu steering clutches, and it is a 404, file not found.....D.....
gatractorman
07-23-2003 16:51:58
No, you dont have to, would make it easier to get a hoist in there if they were out of the way.
