d4 7u cat ?s
mike j in or
07-24-2003 23:02:56
how big a job is brakes and a steering clutch in this it is a 54 it seems to have ok power but should i be able to pull the fire out of it in 1st gear i have done quite a bit of repair on crawlers so i can fix most anything with a manual tractor hasnt run in 2 years and seemed to miss a little under load about how much power should it have ive run jd 420 case 750 ac hd5 and d8 cat it has a 6way blade motor holds good oil press dosnt smoke exsesivly u/c is runnable trans shifts good clutch feels good is it worth 3500 im in southern or thanks mike
Don
07-25-2003 14:02:56
 Re: d4 7u cat ?s in reply to mike j in or, 07-24-2003 23:02:56
Go to acmoc.org, ask on their bb, lots of folks there who can answer all your questions
