AC HD5G Refill Oils.
augie584
07-25-2003 20:45:47
Just purchased a HD5G. The hydralic system calls for 10w SAE oil 15 gallons is that a detergent or non-detergent oil ? Engine and air cleaner oil is 30w SAE detergent or Non-detergent ? And last the transmission and finals use 11 gallons of 50w SAE oil detergent or Non ? Checked with Napa today the Non-detergent is not available except in the 30w SAE. Any help on proper oils will be appreciated. Thanks.
Tim
07-26-2003 16:10:00
 Re: AC HD5G Refill Oils. in reply to augie584, 07-25-2003 20:45:47
Put shell rotella 30 wt in the engine. use 90 wt gear lube in the trans and finals NAPA's hydraulic oil works fine.
Check and see if the steering clutch throw out bearings have been converted to grease lube. if not you should.
You can get a spin on type housings and filters.Convert it to spin on you won't regret it.
Detroit diesel's Fuel filters/housing not to bad about $16 ea 1 primary 1 secondary.
