iH 500c wont move.
Bryan
07-29-2003 19:48:14
Hello posting for a relative. From what I understand the machine will move backwards maybe 50' and stop, then need pulled forward to do again. Will not move forward at all under own power. Possibly torque converter? If so how is it accsessed? Any other suggestions on possible cause? Also interested in reasonable repair manual, new or second hand.
dmorgan
08-10-2003 11:43:13
 Re: iH 500c wont move. in reply to Bryan, 07-29-2003 19:48:14
Had the same kind of problem but my was with reverse. the trans had water in it so we changed the fliud ran diesel fuel in it for 1/2 hour and drained and refield with new hytrans. after a couple hours the fluid was so milky we changed it again. no reverse,took it to the property and put it to work after 4 hours of forward dirving reverse came back. but after 1 hour the trans gets hot and reverse slips not sure why unless the clutches are going. I wouldn't pull the trans unless I had to. what do you need out of the manual?
