Identifying a Case 310 series dozer
back40
07-30-2003 04:47:10
I've got a Case 310 dozer and need to buy a manual and some parts for it. The problem is that the engine looks like it's been rebuilt or possibly replaced(serial# tag is gone) and there is no serial# tag on the left tool/battery box either. I've also looked along the engine frame rails with no luck. I want to make sure I know the correct series of dozer before buying parts, so does anyone know what differences there are between the various 310series dozers? Mine has the manual adjusting idlers, 5 roller with 33 track links/pads, a COMMERCIAL SHEARING front hydraulic pump, CYCLOPAC Model FWG08 air filter with DONALDSON DURALIFE dry filter element #P101246, casting# on engine block reads CWC K96. Can anyone tell me what 310 series I have? Are there any other tell tale signs I can look at that will tell me for sure? Local dealer hasn't been much help when trying to determine what the differences are between a 310, 310C, 310D, 310G etc..... ..... Thanks,
george md
07-30-2003 11:06:56
 Re: Identifying a Case 310 series dozer in reply to back40, 07-30-2003 04:47:10
back40, With 5 roller tack frame , it is either a 310 F or 310 G . Further looking in the parts books show the dry cleaner starting in 310 G serial # 3039619 and after . Email me , might be able to fix you up with parts book. george
