no reverse on a 500c
dmorgan
07-30-2003 19:57:01
Anyone !!!!! If you don't mind I could use some help, please. steering clutches are installed and the machine steers fine. The problem is the reverse still does not work. I installed gauges in the reverse and forward clutch test ports.at first the pressure max was 60 on both, forward works great but reverse is very intermittent actually it engaged maybe a half dozen times. we replaced the trans filters, since the oil was looking milky again. forward and reverse pressure went up to 65 psi and reverse worked for about 2 min traveling 40 ft back, forwards and 40 ft back again. Them it all stopped, so we decided to replace the trans oil/filters once again. after doing so still no reverse. Have you ever taking your pressure readings ? if so what did they read? the manual says at high idle ( what ever that means) 75-78 psi. while engaged and 10-14 in neutral ,what would cause this to be low? page 4-54 says apply and lube pressures must main constant regardless of control valve position. Are they saying at idle the pressure if LUBE pressure and when in gear the Pressure is APPLY pressure, if this is the case I'm thinking I need to adjust the regulators, But what would cause them to change, reverse always worked before. Is there something else that could be causing this problem? could it still be the reverse clutches? if so can you remove them without pulling the trans? What do you think? thanks for the help. Dave
dmorgan
08-10-2003 11:38:37
 Re: no reverse on a 500c in reply to dmorgan, 07-30-2003 19:57:01
reverse is now working. took it to the property and put it to work after 4 hours of forward dirving reverse came back. but after 1 hour the trans gets hot and reverse slips any thoughts
