Stuck tracks
Larry806
08-03-2003 20:33:28
I bought 2 Case 310 dozers that have set well over 25 years. I was told the guy bought both the same year used them only 1 year verry little The tracks are in ex. shape but have set out side and are stuck They won't turn when I try & pull the dozers any one know what to do??? Thank you Larry
Oldfarboy Jim
08-06-2003 14:39:11
 Re: Stuck tracks in reply to Larry806, 08-03-2003 20:33:28
I agree with Tim. You may have frozen steering clutches, brakes, planetary systems, final drives, etc.. Be patient, use lots of diesel fuel and penetrating oil on the tracks. I'm working on a TD340 that has been sitting for over 5 years. I finally got it to start and run after spending a month reading the manuals and tinkering. I finally rebuilt the injector pump with the help of the service manual. Now it starts and runs smoothly every time. Now on to the not moving problem. Good Luck. Jim
Ray
08-04-2003 15:35:39
Larry, I dont know were you are located, but I have a tract press and can press the tracts for you. I am located in Ohio. Let me know if I can help. Thanks, Ray
marlowe
08-04-2003 10:10:05
save your self a lot of time and money and just have the pins and bushings pushed and cleaned up and then put back in if the tracks are that good and sat that long you will NOT get them loss
Tim
08-04-2003 05:44:10
I just came home yesterday after pulling a trailer 520 miles to pick up an IH TD340 that sat for 30 years,I had to come home with out it.The tracks can be loosened up alot quicker with some heat on each knuckle,beating and pounding until they free up and then use PB blaster or even some fuel oil,but be prepared because it might not be the tracks keeping the machine from rolling.The final drives may be froze and all the mechanisem inside too.
Wayne
08-03-2003 21:40:44
Not to give a short answer, but if the tracks are stuck that bad, I don't think anything short of having the pins and bushings pushed out and cleaned up and reinstalled is gonna do any good. That said the only thing I can think of that might do you any good at all is to get 5 or 10 gallons of PB Blaster and liberally soak them every day for awhile. In between soakings do whatever you can to move the tracks, be it pushing and pulling the machine to try to get them to turn, or hitting on them with a hammer, anything to help the Blaster work at breaking them free. I know it's a whole different ballgame, but I used Blaster last week to free up an accordian hinge on a door that the machine operator said hadn't moved in at at least 8 years. That said I know the Blaster is some good stuff, but I can't say if it will undo 25 years of rust or not. Good luck.
cb
08-06-2003 07:10:15
 Re: Re: Stuck tracks in reply to Wayne, 08-03-2003 21:40:44
PB blaster is really GREAT stuff
Glen
08-04-2003 20:06:22
Larry;had the same problem with a 1961 d310 and after removing drive shaft they rolled ,it was engine this machine sat from 86 to 2001 Good Luck Glen
