replacing brake band on J.D.350b
dick
08-05-2003 16:49:58
I have manual,but no experience.will have to do under tree use tree limb for chain fall.any advice will be appreciated.thank dick
Jonathan
08-05-2003 18:33:04
 Re: replacing brake band on J.D.350b in reply to dick, 08-05-2003 16:49:58
release the pressure in the track adjuster..Break the track at the master pin. Remove the sprocket..Remove the final drive on the affected side. Loosen the brake adjustment first.The steering clutch will come out with the final drive...leaving the brake band exposed in the cavity that remains... If you want to get ambitious , you can make a hoisting jig shaped like a large "C" out of square tubing or similar to lift the final drive clear of the battery box or hydraulic tank...whichever side you are doing...
