jd 350
Tim
08-05-2003 17:43:30
I suspect I may have coolant in my oil because when I check the oil you can see what looks like it could be coolant on the dipstick . Is this a common problem with the JD three cyl. diesel. If it is what is the likely problem a head gasket or a cracked head.
Clunkhead
08-17-2003 05:46:00
 Re: jd 350 in reply to Tim, 08-05-2003 17:43:30
You most likely do have that occuring Im interested in knowing what you found. I have a machine with the same problem what did you find and do? I have been told that could be caused by seals under liner seats failing and also pin holes in the liners? Apparently coolent PH is important to prevent these problems. My bud wants to do an in frame overhaul. Im concerned about the moisture being inside the crankcase rusting things.
allen
08-05-2003 18:08:22
Let the machine sit overnight then pull the oil pan drain plug. If you've got coolant in the oil it will settle to the bottom. I'll guess bad cylinder liners. Just did this job on my JD. not too difficult.
