Allis model M
Rex (AZ)
08-11-2003 20:41:20
I am starting to work on my latest project. With a carb rebuild and a gas tank flush, she runs good. The stearing clutches work, so I parked her on RR ties in the shop. Today I removed the stearing clutch adjustment covers. There is some rust and black grease and crud in there. Question is do I do anything about this? This is my first crawler so your information is valuable to me.
stan
08-31-2003 21:52:18
 Re: Allis model M in reply to Rex (AZ), 08-11-2003 20:41:20
I have seen the same thing on mine. To get all the crud out the trans top needs to be removed, and the break bands taken out. Now there is enough room to get your arm in the areaa to clean out the crud. The manual sys to fill the cavity with gas and run, then drain, and fill again. I have done this, but use caution. It does clean the area good. If you do this you dont need to take the thing apart.
