JD 410 B Backhoe
Chuck
08-13-2003 21:30:04
There is a violent chatter when the loader boom is raised. The rear hydraulic system seems O.K. Any help out there? Also would like to get a service manual for the machine.
Jonathan
08-14-2003 20:04:58
 Re: JD 410 B Backhoe in reply to Chuck, 08-13-2003 21:30:04
First try looking at the large line that runs from the transmission to the front pump...see if its been crimped in any way...then if it checks out ok, remove the grille and associated parts to access the hydraulic pump...take off a few of the piston plugs...they are on the outer circumferance of the pump...remove the springs and remove a few pistons...see what they look like...if they are scuffed and are not flat on the side that rides on the cam, then you are in need of a new pump....seldom are those 410B/410C pumps rebuildable...they tend to self destruct quickly...If the pistons removed look ok, let me know...we'll try something else !!!
Chuck
08-15-2003 21:21:07
 Re: Re: JD 410 B Backhoe in reply to Jonathan, 08-14-2003 20:04:58
Jonathan---after I made the first post, I discovered a 40% crimp in the large steel return line along the inside of the right frame below the starter. It's just ahead of the hose clamps. I'll remove and repair it and report back. The clamping brackets seem to be located too low, and are below the bottom of the frame. I'm going to look them over and maybe relocate them higher and out of the way. Thanks again.
gm
08-13-2003 22:11:04
Not sure what is chatterin, but hyd lines sort of chatter when you are low on oil. -Greg
Chuck
08-14-2003 09:41:42
 Re: Re: JD 410 B Backhoe in reply to gm, 08-13-2003 22:11:04
The main loader cylinders don't extend smoothly, even making the bucket shake and rattle when raising, load or no load. Seems to have good down-pressure. Oil level is O.K.
Steve
08-15-2003 18:03:36
 Re: Re: Re: JD 410 B Backhoe in reply to Chuck, 08-14-2003 09:41:42
are the pump drive bushings worn out? This can cause a chatted when the hydrolics are activated
