D6 9U overheating/update.
Michael/WV
08-14-2003 10:51:23
The fan belt has 1"play and I cleaned the radiator with a pressure washer,it was changed over to electric starter, it has a metal line from the back of the head to the top of the radiator,I unhooked the metal line at the radiator and put a bucket under it and filled the radiator with water, water came out the tube when I filled the radiator I left the bucket under the metal line and started it the water that came out of the line was steaming hot while the radiator was normal, when I hooked the line back on the radiator and started it water came out of a small hole in the radiator cap after about 20 minutes I added water to the radiator to top it off and it stoped coming out of the radiator cap it ran normal. what do you all think? Thanks for the Help. Michael/WV
