Track tenchion cylender on IH 125 loader, td 7-8
Jon
08-17-2003 18:34:38
The seals has whent out of the track tenchion cylender. It is letting greese out the back as fast as I can pump it in. Do I have to split the track to remove fork and piston or can I lift it up and aroud things down there to get it out and rebuild it? Thinks Jon
clark
08-17-2003 19:22:07
 Re: Track tenchion cylender on IH 125 loader, td 7 in reply to Jon, 08-17-2003 18:34:38
you have to find the master pin and brake the track, then remove the fork with idler and replace the O ring. check the cylinder for smoothness. if its rough you will have to hone. or replace it
Steve
08-18-2003 04:29:28
 Re: Re: Track tenchion cylender on IH 125 loader, in reply to clark, 08-17-2003 19:22:07
third party image
We have new aftermarket adjusters available if you need one.
