john deere 550 dozer
Jerry O'Neill
08-19-2003 19:23:57
I recently purchased this dozer and ran out of fuel the first time I used it. I need a manual or instructions how to restart it after I add fuel.
Jonathan
08-20-2003 03:42:29
 Re: john deere 550 dozer in reply to Jerry O'Neill, 08-19-2003 19:23:57
Put fuel in the tank !!!...crack open the bleed screw on the fuel filter base. Pump the priming lever on the transfer pump(right side of engine). When fuel starts being pumped from bleed screw, tighten it and loosen fuel line going into injection pump (left side of engine).Follow the line from the filter if your not sure which one to loosen. Pump the transfer pump 'til fuel comes out of loosened line. Tighten the line and give a few more pumps ...Crank over til it starts ...may take a little cranking...shouldn't have too crack the injector lines..
