D4 (7u) track adjust???
denjoe
08-22-2003 04:35:22
Can't seem to find any postings on how to adjust track on D4. Is there a grease fitting for this? What clearance and how to measure it?
Bob/Ont
08-22-2003 13:57:58
 Re: D4 (7u) track adjust??? in reply to denjoe, 08-22-2003 04:35:22
Look under the tinware on the track frame behind the idler. You may have a threaded rod to turn for adjusting or you may have a machine that has been converted to Hyd track adjusters. If you have hyd adjusters there is a grease fitting on the flange of the cyl coming out of the front of the recoil spring.There should be another hex head by the fitting, that is to let out the grease to slack the track. Force the idler out as far as you can then back it off 3/8". Later Bob
