Balmar loader backhoe
randy
04-26-2001 13:02:33
i have a balmar loader backhoe, ford d-60
and i would like more info on it if any more exist or where to get parts etc please e-mail me if you know
thanks
rj
Bruce L.
04-26-2001 18:37:40
 Re: balmar loader backhoe in reply to randy, 04-26-2001 13:02:33
Randy I think that is what a buddie has. It is like a gaint skidsteer? He had it running last fall was thinking of selling but I have not sean it latley
randy
04-27-2001 08:20:01
 Re: Re: balmar loader backhoe in reply to Bruce L., 04-26-2001 18:37:40
Bruce L.
yes it does look like a big skidsteer, i would like more info about your friends or his knowledge about it
thanks
rj
Harold W Polmanteer
02-17-2003 13:25:19
 Re: Re: Re: balmar loader backhoe in reply to randy, 04-27-2001 08:20:01
I own a balmar loader backhoe, mine is a ford dextra tractor once you get inside the chain drive line. I think the brake disks are ford also. Not a good machine for running on the pavement, works well on dirt. Been lifting concrete blocks about 4600lbs each with it and the hoe digs well. Came from a farm dealer in Batavia NY when new. I have worked on the chain drive line, standard 100 chain and found bearings without a problem, other than that it has a rather hard to find bumped o ring style fitting on the hydraulics. Converted most of mine to standard hyd pipe by saving the oring fitting on the end of the hose and brazing a hydraulic pipe fitting on it. Like any old hoe a little imagination a welder and torch will keep it working. Also swaped out the orignal bucket tooth shanks that took teeth that you beat with a hammer to stay on to case style pinned teeth. Any questions you have on the machine I might be able to answer feel free to email
