TD9B Fuel in crankcase
Harvey May
08-23-2003 17:12:09
I had the injection pump rebuilt and put new shaft seals on. I'm still getting fuel in the engine oil after running the engine for about 20 minutes. Could this be a leaking injector, bad pistion, valve, etc. Has anyone had any experience with this type of problem.
JerePa
08-23-2003 19:00:44
 Re: TD9B Fuel in crankcase in reply to Harvey May, 08-23-2003 17:12:09
I would take a compression test to see how the rings are. Chances are, if the compression is low. the fuel is going down past the rings. This happened on my TD35. The rings were shot.
