TD7E International steering problem
Txsbigfoot
08-24-2003 22:43:18
New to dozers, ran fine for a while but has a tough time turning left. Will go right fine but when I pull back the lever it takes it about 10 feet for it to finally start a turn and it will not lock up the track. Pressure on lever seems fine. Any suggestions?
gatractorman
08-25-2003 10:20:46
 Re: TD7E International steering problem in reply to Txsbigfoot, 08-24-2003 22:43:18
Sounds like you just need a brake adjustment on the left side, look at the final drive on that side approx. at a 10 o'clock position from the center of the sprocket and find an adjustment screw with a large lock nut on it, loosen the lock nut and turn the adj. screw in some then try your steering.
txsbigfoot
08-25-2003 18:21:10
 Re: Re: TD7E International steering problem in reply to gatractorman, 08-25-2003 10:20:46
The final drive is the drive sprocket I presume, and the adjustment is just below the top track, is that right? Thanks Mike
gatractorman
08-26-2003 01:36:21
 Re: Re: Re: TD7E International steering problem in reply to txsbigfoot, 08-25-2003 18:21:10
Yes, that is the general location there usually covered in dirt may have to dig some to find it.
