350B Track Adjuster
Jim
08-27-2003 17:16:42
I have a bent piston shaft on a track adjuster does anyone have a suggestion on a parts source or can I get a rebuilt unit? Iam going to check local JD dealer but there prices usually make me sick Thanks Jim B
Clunkhead
08-31-2003 06:29:47
 Re: 350B Track Adjuster in reply to Jim, 08-27-2003 17:16:42
Jim replace the bent unit with one of the newer style if possible. Deere changed the seal type along the way and the older seals wont work on the newer style shafts and visa versa. The newer style use a nylon bevelled type seal the older units used an O-ring type seal. However both will will fit the same bore on your adjuster. I dont have any I can part with but contact Ed at www.crawlerheaven.com he is very helpfull.
Jim
08-29-2003 16:27:26
The end of the piston is too pitted to just replace the extension tube so Iam going to make a complete piston and tube.The JD dealer wants $230.0 for the piston, the barrel is fine all I had to do was hone the cyl a little bit
Roland
08-29-2003 08:39:59
If the piston and seals are in good condition, all you need to do is weld a new shaft on. Extend piston wrap with wet rags to keep cool, no nee to take appart. Make shaft from tube of proper diameter, thickness and lenght.
Nate Schmittgens
08-29-2003 07:35:46
Jim, I sell new aftermarket parts for some of the older JD crawlers. I'm sure I can get you a new rod for a bit less than the Dealer. Thanks, Nate
Pete/ME
08-30-2003 04:05:48
 Re: Re: 350B Track Adjuster in reply to Nate Schmittgens, 08-29-2003 07:35:46
Nate, I've got a straight JD350 and would like to know how to get in touch. Thanks.
CORY MAUPIN
08-28-2003 13:49:57
YOU MIGHT WANT TO TAKE IT TO A MACHINE SHOP ITS A SIMPLE PART TO TURN AND MIGHT COST LESS THAN A NEW OR USED ONE. JUST MAKE SURE THEY CHROME IT.
bob
08-27-2003 21:45:40
buy new. any used parts probably are bad or will soon go bad. I have wasted a lot of time looking for good used ones.
