Case 455 Track Loader question
David
08-28-2003 09:18:33
I have a Case 455D that has a problem with the hydrolics. When I try to bring the loader budket up, it moves very, very slow. The bucket roll-back doesn't work at all. However there is hydrolic power to tilt, bring the bucket down and the rear rippers works up and down. Is there any technical book that will tell me how to fix it? I do have the parts book. Any help will be appreciated.
Brokenwrench
08-28-2003 15:10:41
 Re: Case 455 Track Loader question in reply to David, 08-28-2003 09:18:33
If the machine has a self leveling bucket(bucket curls foward as the boom is raised,so material doesn't spill over the back)Check the linkage and valves for this. This valve/linkage could be stuck diverting oil flow to the lift/tilt circuit.Since all the other functions seem ok I don't think you have a pressure problem.
David
08-29-2003 06:34:02
 Re: Re: Case 455 Track Loader question in reply to Brokenwrench, 08-28-2003 15:10:41
Thanks for the help. I really appreciate it.
Robert Hensell
08-28-2003 12:52:35
1. Is the hydraulic oil reservoir full? 2. Have you changed the filter? 3. With the bucket raised, shut off the engine; will the bucket stay up? 4. Do you have enough down pressure on the bucket to raise the front of the machine? 5. You need a service manual.
Mike
09-27-2003 17:24:05
 Re: Re: Case 455 Track Loader question in reply to Robert Hensell, 08-28-2003 12:52:35
Go to http://hometown.aol.com/mrbean1254/index.html Here you will find the manuals you are looking for and MORE.
