Hydraulic question on a Crawler Loader
Tommy
08-31-2003 16:47:04
I have a International crawler loader and when I'm back dragging with the bucket pointed down it seams to have weak Hydraulic pressure. Sometimes the bucket will not hold and just want to lay flat. Is this a valve problem or pump problem or what?
Charlie
09-01-2003 17:00:11
 Re: Hydraulic question on a Crawler Loader in reply to Tommy, 08-31-2003 16:47:04
I would guess that it's a warn O-ring on the spool of the control valve that controls bucket tilt. The fluid is getting forced back by it when put under pressure by the backdragging. It could be other things, but I think that's by far the most likely. Those other things include piston packing and relief valves, but I wouldn't even think about them before replacing the O-rings on the control valve. This is really easy.
Tommy
09-02-2003 21:40:36
 Re: Re: Hydraulic question on a Crawler Loader in reply to Charlie, 09-01-2003 17:00:11
Charlie, Thanks for the info. I will try to see if I can figure out how to change that part out. Thanks again Tommy..
