Case 580ck engine
Jason
09-01-2003 08:37:02
I need a 188d engine or good block for a 580ck backhoe. I also need info on what engines I could use as a substitute and any info someone has as to what tractors,combines, etc these engines were installed in. thanks in advance for any help. Jason
Tim
09-02-2003 15:26:21
 Re: Case 580ck engine in reply to Jason, 09-01-2003 08:37:02
I pasted the text of a current ad below. I have no connection with them. I just had my engine rebuilt and was considering these guys for an exchange. The companny I learned after calling was Action Tractor co. "ODESSA, FL Call For Price 207 CASE ENGINES REBUILT, IN STOCK 188, 336, 504, TURBO AND NON-TURBO, DROTT CASE PARTS, HALF OF NEW, EXPERT REPAIRS TO ALL CASE EQUIPMENT, CALL ACTION TRACTOR & EQUIPMENT AT 813-926-2598.More Details & Photos (813) 926-2598"
jdemaris
09-01-2003 16:07:37
A 207D will interchange with the 188D. I've got a basket-case 580CK that's been sitting in my barn for three years now that has a blown 188D. I picked up a low-hours 207D engine and have intending to put it into the hoe, but the way things are going, I'm not sure if I'll ever finish it. I've got two other hoes now and don't need the machine, so I haven't been motivated. I did check all measurements as far as the swap goes. A few parts have to be swapped off the old engine, e.g. the starter motor, oil pan, timing cover and water pump. Tell you the truth, I wish I could find someone to buy the whole deal and get it out of here.
Jason
09-02-2003 07:28:36
 Re: Re: Case 580ck engine in reply to jdemaris, 09-01-2003 16:07:37
were are you located? I'm in western N.Y. Jason
jdemaris
09-02-2003 17:50:56
 Re: Re: Re: Case 580ck engine in reply to Jason, 09-02-2003 07:28:36
I'm in central NY equidistant between Albany and Binghamton and 15 miles from either Cooperstown,Cobleskill or Oneonta.
Esev
09-02-2003 18:00:49
 Re: Re: Re: Re: Case 580ck engine in reply to jdemaris, 09-02-2003 17:50:56
Not to cut in on you guys, but I could use a couple hydraulic cylinders off that 580 if it ends up going for parts. Thanks, Esev
gatractorman
09-01-2003 10:07:58
LOL, go ahead and find 2 while your looking I need one for a 450 Case dozer I need a rebuildable core engine, block and head is busted and crankshaft is ruined. Think people are subbing that 4-cyl B-series Cummins for the 188 Case.
