Starter on TD 14A
Kovel
09-01-2003 18:19:10
Tried to start my 14 and starter sounds like it is not engaging into ring gear.When you hit the start button,it sounds like the starter works,but is not meshed with the ring gear.I pulled starter out,and tried it and starter works.The motor is not locked up because I can turn the crank.Any idea's?
Earl
11-27-2003 15:46:51
 Re: Starter on TD 14A in reply to Kovel, 09-01-2003 18:19:10
Need to look at the ring on your fly wheel.
Milton
09-02-2003 10:54:05
Hello Kovel, --- 2 / Sept. / 2003 --- It sounds like the benix spring is broken (or a pin that holds the spring). The gear on the starter is OK - isn't it ? Milton
Steve
09-02-2003 10:52:03
third party image
Sounds like the bendix is bad.
