Case 350 problems . .
Windancer
09-02-2003 01:40:40
Couple of minor annoyances with my Case 350 dozer: after working it, sometimes it surges during idle. Power up and it's OK. But idling up close to something I don't want to contact- it's a little tricky. Secondly, a track on one side loosens up over a couple of days. A couple of shots of grease in the adjuster and it's OK but won't stay that way. Anybody been there, done that?
J Mann
09-03-2003 16:10:12
 Re: Case 350 problems . . in reply to Windancer, 09-02-2003 01:40:40
We have an 850D and the same problem with the track adjusters one went one week two weeks later the other. We purchased replacements at Depco in Indiana for 560 A side. These are not available through case, our 850 is a 92 model and we had to get aftermarket. The injection pump may be repaired on the tractor if it is only adjustment problem.
Windancer
09-03-2003 01:21:00
It's a diesel, I think 188 CI.
Terrance
09-02-2003 04:43:46
Is this a G350 or a D350 ,gas or desiel? Could be governor adjustment. The track problem can be fixed by installing new packings in your track adjusters, same cure you would use for a hydraulic cylinder that leaked down.Parts are available at any Case dealer and also many aftermarket suppliers. Good luck terrance
Steve
09-02-2003 10:58:27
 Re: Re: Case 350 problems . . in reply to Terrance, 09-02-2003 04:43:46
third party image
Very often as tracks wear and the adjuster is pushed out, the seals inside come in contact with a rusty wall inside the adjuster. The wall is sometimes pitted so badly that even new seals won't last. At this point there are really only 2 options. 1....have the adjuster bored out and a sleeve pressed in to return it to original size, or 2....replace the adjuster. There are aftermarket ones available at reasonable prices. Contact us directly if you're interested in a new aftermarket.
