12 volt positive ground???
Gatractorman
09-05-2003 02:34:50
I was out looking at an old Allis-Chalmers backhoe the other day, gas burner, with a 12 volt positive ground electrical system and of course the battery was weak, so not knowing for sure I declined his request to jump it with my truck, so how do you or can you jump a 12 volt positive ground with 12 volt neg. ground system? I did take the battery out for him and he's got it on charge.
jdemaris
09-05-2003 05:27:15
 Re: 12 volt positive ground??? in reply to Gatractorman, 09-05-2003 02:34:50
You hook up the jumpers just the same, regardless if the system in either machine is positive or negative ground. Positive goes to positive and negative goes to negative. Paralell connection results in 12 volts regardless of amount of batteries or grounding polarity. Just don't have the machines making direct metal contact with each other.
gatractorman
09-07-2003 04:36:24
 Re: Re: 12 volt positive ground??? in reply to jdemaris, 09-05-2003 05:27:15
Thanks for the info., was just a little uneasy about smoking the electrical system in my truck.
