Where to find spacer for Case 350 sprockets on 310
Ken McWilliams
09-06-2003 20:31:17
I have a CASE 310 crawler for which I have replacement Berco sprockets made for a CASE 350. I need the spacers that go behind the sprockets to make them fit my 310. Where can they be found and how much?
RAB
09-07-2003 00:00:59
 Re: Where to find spacer for Case 350 sprockets on in reply to Ken McWilliams, 09-06-2003 20:31:17
Have you tried Berco or their stockist? Probably a good place to start. They might even supply. Must have had the same enquiry before, I would think. Regards,RAB
Terrance
09-07-2003 12:29:05
 Re: Re: Where to find spacer for Case 350 sprocket in reply to RAB, 09-07-2003 00:00:59
Ken, Berco use to carry them in the past, they still may. You could also make them yourself,if memory serves me correct they are 1/2" thick ,inside diameter is slightly larger than axle,outside diameter is the same as your sprocket.The hardest part is finding a suitable piece of tubing to make them. Crawler haven should have them as well. Good luck Terrance
