TD 15B power shift won't move
K. C. Robertson
09-17-2003 01:58:31
I started my TD 15 yesterday after sitting 5 years the emgine started fine but the tractor won't move. It shows no transmission clutch oil pressure or transmission lube pressure. I have changed or cleaned all the filters. Can anyone tell me where to start looking for the problem. It was running fine when it was parked
Jim
09-18-2003 18:54:57
 Re: TD 15B power shift won't move in reply to K. C. Robertson, 09-17-2003 01:58:31
Check to see if the oil level goes down on the trans dipstick and if te drive shaft is truning real fast when running - if not the charge pump is not working. Try blowing air into the dipstick tube with the engine running sometimes that will get it to pick up the prime if not check your hoses and the suction screen to make sure not sucking air.
gatractorman
09-17-2003 02:51:22
I'm not familiar with the TD15 but it sounds like the charge pump has not picked up oil yet, is there anything on the pressure side of the charge pump that you could loosen to let some air out? Like a hose that goes into a filter?
