JD440IC Clutch adjustment
Bob
09-19-2003 19:44:11
I purchased a JD440IC from a Mennonite equipment salvager who I mistakenly assumed would be more honest than most others in that business which was just the beginning of my problems. I’m trying to work through them one at a time. I’m currently trying to adjust the main drive clutch and this is the problem. The clutches shown in the service manual doesn’t look like what I have. My service manual shows 2 types for units with reversers. (1) Adjustment by the linkage and (2) adjustment by screw on the shaft going the clutch housing. Mine has neither of these. It appears that the linkage from the pedal shaft is enclosed through the reverser to the clutch housing and there is no apparent way to adjust it. I have ports on each side of the clutch housing but in the absence of direction I still can’t see an adjustment. Am I missing something or do I have a clutch and reverser from another model JD model that I need to get familiar with. I know some of you guys out there have a wealth of experience with these things and any advice will be appreciated. Thanks in advance....Bob
Lavoy
09-19-2003 19:48:24
 Re: JD440IC Clutch adjustment in reply to Bob, 09-19-2003 19:44:11
Bob, Either you are missing something, or the crawler is missing something. The linkage is not through the reverser housing. It may be real close to the lower left side, but it is not inside the reverser housing itself, there would be no room. Lavoy
