D21A-7 clutch engages harshly
Martin
09-24-2003 08:12:30
I have a D21A-7 Dozer, 1999 I believe. Last week the clutch started to engage very harshly. It was working fine one day, the next it was as though it was either on or off. Engaging in forward or reverse caused a real clunk. Steering under load is also jerky. I pulled the valve out and nothing seemed broken, although there was light wear on the one end. (only 2000 hrs) It seemed to slide ok. Any adjustment? Any ideas?
JimInOz
09-26-2003 20:27:41
 Re: D21A-7 clutch engages harshly in reply to Martin, 09-24-2003 08:12:30
Not 100% sure on this unit...check all relevant oil levels.My BD2G had a slow leak in steer system & drained all clutch oil.Result:jerky steering/hard shifting gear.Luckily I found leak in quick time.Buy a manual also.
