350B Steering Clutch Problem
Jim
09-24-2003 16:50:03
I just replaced steering clutches on my 350B dozer this is the second side that I have done, my problem is after I assembled the final back on the machine there is no sring back in the lever and the clutch doesn't ingage to stop the track is this a adjustment problem? or is the clutch plate no good I set the clutch sprng height with a JD7 tool just like on the otherside and I have the proper amount of plates and discs in the housing the only differance is I bought a aftermarket clutch plate for this side Any Ideas on what is going on? Thanks in advance for any help
jtilson
09-03-2004 06:31:28
 Re: 350B Steering Clutch Problem in reply to Jim, 09-24-2003 16:50:03
Jim I have same problem that you described with 350B steering on Sept24,03.
Did you get it fixed and could you tell me how?
jtilsond@yahoo.com
appreciate the help
jdemaris
09-27-2003 16:43:41
I'm not quite sure what you're describing. The clutch does not engage to stop the track, the brake band does that. If the clutch won't engage at all (to drive the track), look down inside with a flash light to see if the throwout bearing is clear of the pressure plate fingers.
