street shoes
Rex (AZ)
09-26-2003 19:11:44
I am just finishing the resteration on a allis model M. I have never seen any postings on the best way to put street shoes on the gousers. The original manual showes some steel pads that bolted on for street use. I called a rubber supplier,there cost for 62 pads was more than I can afford. I own a weld fab. /machine shop so I can do a lot of work. Any suggestions?
Oldfarmboy Jim
09-27-2003 10:49:25
 Re: street shoes in reply to Rex (AZ), 09-26-2003 19:11:44
Rex, If your're looking for inexpensive hardwood, get some old wooden pallets. Those stringers are about 2X3, sometimes 3X3 and are they tough! Try taking one apart sometime.
Shawn Bierworth
09-27-2003 04:01:22
Take a look at my crawler on the tractor photo's page under "1959 International T5 Farm Crawler" as you will see what I used. I made up Elm pads that bolt up to the growser pads and they have a generous radius all around so they don't mark up grass. Works well and I haven't had any complaints from any of the show grounds when this machine is showed. Shawn
Rex (AZ)
09-27-2003 04:18:15
 Re: Re: street shoes in reply to Shawn Bierworth, 09-27-2003 04:01:22
Shawn, It looks like you did a great job on your tractor. I dont think there is any place in Phoenix that I could buy elm. Where did you get yours? and how much would it cost?
Shawn Bierworth
09-27-2003 05:40:50
 Re: Re: Re: street shoes in reply to Rex (AZ), 09-27-2003 04:18:15
My father has a small saw-mill.Elm is quite common in Southern Ontario. It doesn't have to be Elm,, just a tough hard material.
