49BEAR TD9 drott update
Mark
10-01-2003 17:12:36
I was able to drop the oil pan and change out the damaged main and rod bearings, the center main was seized. I used very fine grit sand paper to polish the journals. I had it running today and it holds 42 PSI oil pressure at idle at run temp. Now if I can figure out what is wrong with the steering clutch on the right. It seems to be stuck open and won't drive. Thank you very much for shareing your knowledge about the old machine, you were a GREAT help!! Mark
mark
10-01-2003 17:42:03
 Re: 49BEAR TD9 drott update in reply to Mark, 10-01-2003 17:12:36
that is good news glad to be of help now about that steering clutch had td9 years ago that would drive both tracks in reverse but not in forward problem was the shaft coming out of the clutch was floating back and forth going foward shaft would come inward putting pressure on clutch and disingage it . bearing cage was bad in final drive housing . big job .remove plate above steering clutch move machine back and forth under power and watch shaft. hope that is not your problem it was a big job good luck
