G-188D Case Eng.
Doug
10-03-2003 17:39:50
Have found a 580CK Hoe Pretty much junk But has a good Motor (Motor SN 2696386) Can any one tell me the year and what one would be worth. Could use it in my 450 Case Dozer if the price is right. Thanks DOUG
gatractorman
10-04-2003 02:48:10
 Re: G-188D Case Eng. in reply to Doug, 10-03-2003 17:39:50
Whats wrong with the engine in the 450? If it just needs a rebuild I may be interested in it if you do the swap, got a 450 here with a bad crank, busted block and head.
Doug
10-04-2003 04:52:45
 Re: Re: G-188D Case Eng. in reply to gatractorman, 10-04-2003 02:48:10
One In My 450 Came out of a older 530 Hoe And has a cracked head or head gasket Eng get's up to 220 Degrees then cools down to normal after cold start and some bubles in radiator, Just wondering what's used eng worth.?
gatractorman
10-05-2003 03:47:50
 Re: Re: Re: G-188D Case Eng. in reply to Doug, 10-04-2003 04:52:45
I'd say in the $1500 range for a good running take-out with no problems.
Tim
10-04-2003 02:47:54
You can find 188D rebuilt for $3500 to $4500
Doug
10-04-2003 04:54:07
 Re: Re: G-188D Case Eng. in reply to Tim, 10-04-2003 02:47:54
Thanks Just wondering what a used motor was worth
marlowe
10-03-2003 19:49:58
same engine
Doug
10-04-2003 04:55:32
 Re: Re: G-188D Case Eng. in reply to marlowe, 10-03-2003 19:49:58
This I know case i put the one in it out of a 530 hoe.
