JD 450b steer brake noise, gear noise
arnold b
10-05-2003 19:52:30
i have been a mechanic at a county garage for 10 yrs but have no crawler experince. i have just accuired a jd 450 b dozer. i have 2 problems and no manual. first problem is the steering clutchs/brakes sound like metal to metal when trying to turn. the last owner said it hasent been operated much sence new ones installed and i pulled the covers off and they do look to have plenty of material left but still make alot of noise. also the foot brake makes the same noise. second problem is that in order to change gears[1,2,3,4] i have to shut the engine off or the gears grind, is this normal,i would guess it is not normal and just needs clutch adjustment. any input would be apprichated thanks, arnie b.
Gus
10-09-2003 17:51:53
 Re: JD 450b steer brake noise, gear noise in reply to arnold b, 10-05-2003 19:52:30
Mine makes a terrible noise if the clutch/brakes aren't adjusted correctly. When pulling back on the lever, the clutch won't disengage all the way and the brake engages. They fight each other. Adjustment takes care of this.
