TD6 Gas/Diesel Carb Kit
Tim
10-06-2003 09:23:35
Does anyone know where I can get a carb kit, rebuilt carb or a new carb for a TD6 gas/diesel engine S#TDBKM17450. My carb requires half choke to run. When I push the choke lever all the way in the engine stalls.
clark
10-06-2003 14:17:15
 Re: TD6 Gas/Diesel Carb Kit in reply to Tim, 10-06-2003 09:23:35
Tim, the carburator has no moveing parts other than the float & needle valve. there is kits availible from bates.com but yur really going to have to dig DEEP in your wallet. i would sudjest that you check the fuel flow from the gas tank to the carb. if it has good flow to there then take the carb off and do a good cleaning inside & out. If the top gasket the fits between the 2 halves of the carb is bad then get some gasket material and a small ball pien hammer and make a new gasket. if the problem still presist then its not the carb. the only other thing it could be is the butterfly valves in the manifols are not opening all the way in gas starting position. my TD-6 had this problem. i removed the intake manifold and cleaned and lubed the shafts. then i had to adjust the lever thar runs through the head from the injector side. you might want to get a service manuel to do the adjustments.
Tim
10-09-2003 07:15:06
 Re: Re: TD6 Gas/Diesel Carb Kit in reply to clark, 10-06-2003 14:17:15
If I remove the intake manifold, will I need a gasket for that?
IH TD-18
10-06-2003 13:36:43
Try FPSmith out of California. I think the adress is www.fpsmitheq.com Talk to Chris Estes
gm
10-06-2003 12:42:10
You might check that your manifold is sealed good. I had that problem before and it was due to me not tightening the manifold mounting bolts. Either that, or your carb might just need a good cleaning. Its not very complicated, and there is nothing in there that really wears so a rebuild kit shouldnt be necessary. -Greg
