450 case crawler has no go power
jim ucci
10-06-2003 15:08:17
I recently purchased a track loader from a tech school.This tractor is in excellent condition-never did a hard days work since it was new.It sat in a storage building for the last eight years,I changed all the fluids,filters and cleaned the screens. The problem is it has no pushing piwer, the right tract struggles just to move the tractor alone.the left seems better,the torque conveter pressure gage reads 75-100 when it tries to push.Every thing else seems fine.
Steve Schmittgens
10-09-2003 14:45:21
 Re: 450 case crawler has no go power in reply to jim ucci, 10-06-2003 15:08:17
Jim, Call me @ (314)966-6692, I have some tips that might help you out or may help diagnose the problem. Steve
Jc marleau
10-06-2003 18:30:27
I have maybe used parts my e mail is jcmarleau@aol.com
marlowe
10-06-2003 15:46:45
do the foot brakes work at all and dose it get worse the more you run it ?
jim
10-06-2003 17:03:49
 Re: Re: 450 case crawler has no go power in reply to marlowe, 10-06-2003 15:46:45
marlowe, I just put two new master cylinders and slaves in.It seems to have had both brakes working,after an hour of running I lost the steering in the right track when I applied the left brake.
jim
10-06-2003 16:11:13
marlowe
10-06-2003 20:39:20
 Re: Re: Re: 450 case crawler has no go power in reply to jim, 10-06-2003 16:11:13
they have had some trubel with the foot brakes building pressure and releasing the clutchs just bleed the lines and leave them loss and try it notheing lost but i bet it will fix it. i have 3 450 and for some reason one did this after you would use it and it got hot
marlowe
10-06-2003 20:45:05
 Re: Re: Re: Re: 450 case crawler has no go power in reply to marlowe, 10-06-2003 20:39:20
all so you should [[[NOT]]] use the foot brakes for all your turning it is not the way they were intended to be used use the power steer [the two levers between your legs] the foot brakes are only for close quarters
