JD 350-b engine removal
Brian
10-12-2003 07:45:56
Do i need to remove the front nose or the radiator to remove the engine from the tractor?
Steve B
10-13-2003 17:51:55
 Re: JD 350-b engine removal in reply to Brian, 10-12-2003 07:45:56
Brian, You do not need to rmove the radiator for this job, that's cool. You should remove the nose, dash assembly,skid plates,floor plates and engine mounting bolts. It will come right out pretty easily.
SteveB
10-13-2003 18:10:17
 Re: Re: JD 350-b engine removal in reply to Steve B, 10-13-2003 17:51:55
Lou , Go to WWW.THEPAPERSHOP.com look at veiw display adds for nationwide parts service. Later Steve
Jonathan
10-12-2003 08:32:21
Remove the nose assembly. The radiator can remain on the engine when it comes out
Pete/Maine
10-13-2003 05:31:03
 Re: Re: JD 350-b engine removal in reply to Jonathan, 10-12-2003 08:32:21
I took mine off, figuring it was a good time to take it to a rad. shop for flush. Also pretty easy to do damage to the rad. when moving the engine around.
