Ford 550 backhoe hyd pump blows out
Bret
10-12-2003 17:17:24
I need to replace the presure relief valve on my 70's vintage ford 550 backhoe...replaced the 2nd hyd pump already..anyone have info on how to replace the relief valve causing the pump to blow out???
Alvin n Ms.
10-12-2003 19:03:58
 Re: Ford 550 backhoe hyd pump blows out in reply to Bret, 10-12-2003 17:17:24
I have been runing Ford backhoes for 29 years, and it would be my guess that someone has been runing yours out of hydralic oil.
Alvin n Ms.
10-14-2003 05:51:32
 Re: Re: Ford 550 backhoe hyd pump blows out in reply to Alvin n Ms., 10-12-2003 19:03:58
When you say blows out does that mean blowing out oil at the input shaft to the pump? The shaft that drives the pump could be out of line and putting to much strain on the seal and wear on the bronze sleeve at the front of the pump. If the pressure is to high it will burst hoses real often, when digging with the hoe.
