Case 580 CK losing power
S. Conner
10-14-2003 20:37:20
I've got a 580 CK Case backhoe with a 159 gas engine. It runs fine when I'm working with it but when I'm going down the road in high gear, it will start to miss and cut out and it will finally die. After it sits for a minute it will start right back up like nothing happened. The last time it did it, when it started missing, oil started puking out of the air breather. That's never happened before. I've got my suspicions it's a fuel problem. I put electronic ignition on it about a year ago and the timing is set just like it's supposed to be and the cap, rotor, plugs, and wires were all replaced the same time. I appreciate the advice. Thanks.
