Dead D4 dozer
Leo
02-17-2000 18:39:54
What would a Cat D4 (1947) weigh? Haven't found any body interested in hauling it 180 miles. What size truck or trailer would be needed?
Skinner
10-17-2001 12:02:54
 Re: Dead D4 dozer in reply to Leo, 02-17-2000 18:39:54
If the D4 has a PTO you could drive the PTO with another tractor...making sure that you turn it in the proper direction. (A D4 PTO unit has forward and reverse). Might be able to run the hydro by using the decompression release so as to turn engine. Might be able to crawl onto a trailer too.
Shawn
02-22-2000 07:48:17
Leo, A bare 6U D4 weighs 10,065 pounds.
for straight blade & hydraulics add 2685 lbs.
If it has a belly pan and rock shields on the bottom rollers add a few hundred more pounds. Now you are up around 13,000 pounds minimum.
I have hauled home three Dead D4s and an HD5 loader. Each was an adventure. One of the first things you have to do is lift the blade. I use a 4ft. farm jack to lift the blade nice and high. This will compress the hydraulic cylinders. Then take a couple short pieces of 3/8" chain with hooks and chain the blade up from the rear of the hyd. cylinder to the "triangle" on the lift arms. Get the blade as high as it will go because this will make it easier to winch up onto a trailer. We hauled mine on a 9-ton tri-axle trailer. It is best to have a trailer with a winch on it to load with. I used a chain come-along to load the HD5 and that was a good work out. Slow but sure. We loaded them on front first but you may have to do it rear first. You will need something to pull the D4 off the trailer when you get it home so keep that in mind. I used a wheel tractor once and a D2 the other times. We hauled mine with an old one ton Ford with a 400 V8. The farthest we hauled was 60 miles. The most important thing is to have good brakes and to leave plenty of space between you and the guy infront of you. Good luck, I wouldn't sell a gift like that either.
Shawn
Thanks
02-21-2000 17:09:00
This D4 ,serial no. 6U694,is narrow track with a hydraulic dozer blade, no angle. It is pretty tough looking as it has never seen a shed, I think. It is sitting on fairly level ground, a little sunk into the dirt.The last years of it's life, it was pulled to start and used on tree stumps, clearing rich bottom ground (now called wetlands, I think). I could dig a hole under the blade and run a cable back to something under the tractor. But that blade looks pretty heavy. My father-in-law gave it to me, a city dweller many years ago. Now I have an acerage, a nice machine shed with a new heavy smooth floor, but I don't have any heavy lifting equipment or pickup big enough. Several tilers have turned me down or not responded when the tractor wasn't frozen down. It is located in central Iowa. I won't sell it as I think the world of my father-in-law...it would hurt him, I think. Thanks, I will be listening.
chappy
02-19-2000 14:34:07
T16
A D4 can easily be moved without hiring a heavy transport if you have the right equipment. I move my TD9 and D4 7U using a three axle car hauler and a 3/4 or 1 ton pickup. Moving it wouldn't be a problem, only sudden stops. I didn't catch where your from, I move several around in Southern California.
Chappy
T16
02-18-2000 19:29:25
My FIL has a D4 with hyd blade, he hauled it on a a triple axle gooseneck, pulled with a 79 F-150 with a 300-6 under the hood, it's fairly hill around here. Figured it weighed about 8 ton with the blade.
Shawn
02-18-2000 02:49:07
Leo, Is it a bare tractor? Does it have a blade and or winch? Is it narrow or wide gauge. If it has a blade, is it hydraulic or cable lift?
A bare tractor weighs a little over 5 tons.(10000 lbs). Give me an idea of what kind of equipment it has and I will give you a better idea what it weighs.
Shawn
jon
03-11-2002 21:50:33
 Re: Re: Dead D4 dozer in reply to Shawn, 02-18-2000 02:49:07
HI I HAVE A D4 WITH BLADE AND I USE A F-350 7.3 AND A 3 AXEL TRAILER..
Mudcat49
02-17-2000 20:23:11
I haul a D-4 7U, with blade on a 9 ton 3 axle goosneck pulled by a F-250 with the 6.9 IHC motor in it, but I am down here in Florida with no hills
FRED
02-17-2000 19:05:35
I am working on a D4 5T about a 1945 with dozer it is 12-13000lb.
