track pins
ken
10-18-2003 12:45:18
I can't find eanyone within 200 miles from me to turn track pins.Im in east texas.its a small 40 horse dozer, eany one know where I might get it done are doe's eany one think a 25 ton log splitter might press them out.
KSTX
10-20-2003 09:21:11
 Re: track pins in reply to ken, 10-18-2003 12:45:18
If you are in the Henderson area, there is a track press shop on HWY 64. I believe that the name of the shop is R.T. Smith. Also, HOLT (Cat) in Longview and Future Equipment (Case) in Tyler have track press capabilities. Hope this helps.
Bob
10-19-2003 07:11:01
I don't know where you are but I known where east Texas is and there are at least a dozen places in either Houston or Dallas that rework track. You need to do some checking with local construction people. Good luck.
Alvin n Ms.
10-20-2003 17:26:31
 Re: Re: track pins in reply to Bob, 10-19-2003 07:11:01
How about Longview, Tyler,and Shreveport.
Alvin n Ms.
10-19-2003 06:30:02
Most tracks have a master link. Some Cat. have bolts and JD master pin is indented, but you must look very close to find them. They can be driven out with a 20lb sledge hammer, and a smaller pin with a small rod welded to it for a handle so you won't hit your hand,and wear heavy gloves to protect from vibration. Have the pins about the same place just in front of idler, so you can lay the track down and drive off onto two 20ft pieces of channel iron, lips up, on good ground. Roll tracks up and take them to most any track shop.You will feel like John Henry just doing this. Good luck and do be careful, as this job could be hazardous to your well being.
marlowe
10-18-2003 17:42:47
with 25 ton you will not even dent the rust. most ind. dealers will know of some one
bob
10-18-2003 22:31:06
 Re: Re: track pins in reply to marlowe , 10-18-2003 17:42:47
Our local junk man has one to take apart junk tracks. Junk 3 ft. long or shorter pays a better price & this saves acethylene
Jonathan
10-18-2003 15:58:14
...theres more involved than just being able to push the pins out...maybe ask any local construction companies who they deal with...sometimes there is a mobile track press company or one man show that doesn't need to advertise...
