Case 450 C - Converter Temp Sensor Location
Scott C
10-19-2003 13:20:25
I recently purchased a 450C and the Temp. guage for the converter/transmission does not work. I bought a new gauge and assumed I would just follow the line/cable to the sensor location. The line was cutoff and I cannot find the sensor anywhere. I found the converter oil pressure gauge line coming from the top of the converter housing and another line running from the right side of the converter housing to the radiator. I called the Case dealer and they told me the sensor should be located on top of the transmission. I found a sensor of some type that I believe was hooked up to the backup horn but nothing else. Can somone please tell where the converter/trans. sensor is located on a 1991 Case 450C dozer? Also, what size allen wrench is needed to remove the transmission drain plug and the engine oil drain plug? Thanks!
Bob/Ont
10-19-2003 19:34:42
 Re: Case 450 C - Converter Temp Sensor Location in reply to Scott C, 10-19-2003 13:20:25
Scott, they are usually on the line from the converter to the Cooler/Radiator and right at the converter. They may have removed it and pluged the hole. Look foir a pipe plug the size if your sender. Later Bob
Scott C
10-20-2003 10:25:58
 Re: Re: Case 450 C - Converter Temp Sensor Locatio in reply to Bob/Ont, 10-19-2003 19:34:42
Thanks for the help Bob. I did find a plug in the converter housing just above where the line going to the radiator is tapped. The plug size matches the new sensor size/threads. I will check the fitting on line itself again to make certain I did not overlook a plug in the line fitting.
Bob/Ont
10-20-2003 11:04:24
 Re: Re: Re: Case 450 C - Converter Temp Sensor Loc in reply to Scott C, 10-20-2003 10:25:58
Scott, it needs to be in the oil flowing out of the converter to the cooled to read right. Later Bob
