Case 310 No Go
Brad
10-19-2003 17:13:23
I have been using my Case 310E dozer for clearing some ground. Today, when in reverse, it started making a grinding noise, but reverse was still working. When I tried to go forward in 1st gear, it wouldn't go. It acted as though I had the brakes on. When I let out on the clutch, the engine would bog down. I can go forward in 2nd or 3rd ok, with no noise. This started all at once. Anyone got any ideas where to start looking? Your help will be much appreciated. Thanks Brad
ED
10-20-2003 12:47:15
 Re: Case 310 No Go in reply to Brad, 10-19-2003 17:13:23
Brad sounds like shifter in two gears and worn out common on these also with that age a machine would not hurt to check tranny and rebuild worn parts reverse gear bearings wear out and shafts as ED said in last post if you need parts i have them you can email me will send link to my site
r_d97
10-20-2003 07:31:02
Sure, start looking at the 1st/reverse shaft in the transmission. Unfortunately you have to split the tracks, pull the final drive off on both sides and pull the transmission/planetary out of the frame to take the transmission apart. If you are really lucky it might be the outer bearing on the 1st/reverse shaft and you might be able to replace that without pulling everything. If you pull up the floorboards and take the gearshift off you might be able to get a good look at the problem. Edward
Jcmarleau
10-19-2003 19:39:31
Brad if this can help you i have parts catalogue or operator manual. my e mail is jcmarleau@aol.com
